Cwall22
Hi,
i've just bought a seat ibiza 1994 1.9 d and the heaters were working fine, then, i started the car again and they didnt come on ive checked the fuse and the relay and they both are working.
has anyone come across this problem before or know of a way of fixing it ?
thanks for any help
when you say heaters, do you mean the fan heaters? or rear window heaters? if its the fan heaters, check the coolant resevoir is topped up, as if its running low enough it will cause an air lock and you'll have no heating! other than that i don't know?
ive just checked that and it seems it was full although my rad fan is working either i don't think so it could be a problem with the wiring :(
cheers i just checked under there and there was a wire looking quite bare so i gave it a wiggle and turned the ignition and i had heaters :)
so im just goin to put some insulation tape around the wire :)
has it been raining? wen it poured down once my circuit board got wet and blew up, my heater blower also seized, try takin the pollon filter out from under ure bonnet and see if ure blower spins. or to check the circuit board has a current try testing it with a multimeter if u have one.
