HELP PLEASE! Oil pressure warning while switch on
leon.il
26
Hi guys, how are you.
I'm an owner of Leon Cupra 2011.
Almost every time that i open switch (sometimes i open the switch and its not happening), i have that warning.
https://www.youtube.com/watch?v=_pUz96K-x4E
anyone had the same issue maybe ? Know about it ?
It's strange that its appear while car is stationary - the engine is even not powered on, just the switch is ON.
Car is working perfect while engine on and while driving.
Appreciate if someone have any answer
BTW Some pics of my awesome Cupra :)
Cabbage
55
Love the colour mate ! Wish I had a sunroof but couldn't find one when looking and I'm too impatient to keep waiting lol
Again sorry I can't help with the issue but I'm sure someone will be able to on here
golfhappy
144
Scotland
Scan with VCDS, possibly an intermittent fault with the oil pressure switch. If the loil level is ok, no nasty rattles from the bottom end, switch wiring fault?
In the pictures you posted is the front number plate the same as the rear? as you've covered up the rear!
vicalva
Cup Racing R - Legend
Aug 13, 2003
74
Madrid
Could be a broken seal at the tip of the dipstick. Easy and cheap to replace. Check if the plastic at the top of the dipstick is damaged, that would cause a drop in oil pressure.
leon.il
26
Hey , already scanned - no faults :( , number is same , just in one of the pictured where it was covered the foto was made by photographer so he covered it;)
leon.il
26
Nope , the dipstick is ok also , i've talked with one car technician yesterday - he told me that there is an a unit in the bottom of the engine and its probably faulty
Thanks mate :) i even didnt knew that there is models without sunroofs :-o , it's the same as i wish to have bi-xenon ;)
KebabWarrior81
1,841
Sandbach,Cheshire
Could it be your oil pickup pipe getting blocked? Is it regularly serviced? How many miles has it done?what oil do you use? Do you ever use engine flush when doing an oil change?
stu 157-330
80
West lothian
I might be wrong here, but if the oil pressure switch is mechanical it won't show on a diagnostic.. Still I'd agree and fit a new pressure switch.. Which is an inexpensive part
