Our Leon FR TDI is currently at the dealers with the clutch having gone a second time, the car has only done 950 miles!
The dealer is alledging that the damage is down to the driver and not any mechanical fault. Previously they changed the clutch, flywheel and release bearing but nothing else.
The dealer is saying there is nothing else there to fail and therefore it must be from the driver slipping the clutch or starting in the wrong gear
Can anyone advise just how the clutch set up is on the FR TDi? I know its hydraulic but does it have its own master cylinder? The dealer showed me how the release bearing is also the slave cylinder - very clever, but they says its sort of Pedal-master cyl-pipe-slave cyl-clutch and they've inspected the master cylinder and pipe and theyre ok.
Now i've read the recall notice re dual mass flywheels, it refers to a "non-optimally designed through-flow restrictor in the clutch pressure pipe." and the fix is "replace the flywheel and the breather of the clutch pressure pipe"
I've no idea of a build date for this car but i'm assuming its built after the affected chassis ranges for this recall. But still, that means that there are other parts the dealer hasnt mentioned, especially the "through flow restrictor"
Any help really is appreciated, cos the dealer wants £1500 to fix it!!
they want you to pay the costs =£1500
