deanr1
Offer is there, but not until Sat PM (next week)
sounds more & more like a blockage
Thanks Mark, i'll take you up on that.
I bet if you swap your ECU for a good one it'll run fine, same thing happened to someone else, car got stuck in some kind of limp mode
Have you had the car from new?
Probably already has revo on there
I reckon their machine has buggered something ECU related, but until i know for sure i wont name names.
Has the ECU been flashed back with standard stock code?
Any sensors you would expect an Audi man to have checked...
Can you free rev it over 5.5k? does it stop dead on this mark or just get there and die off...
I have owned it since it was about 18 months old with 20k on the clock.
I have a minor update for you all, i'm getting the car back tomorrow but its no different as the Revo dealer have admitted defeat and cannot find whats wrong with it despite having it all week.
I'm not sure what to do next, i want my boost back!!!
noone has removed and refitted the n75 wrongly have they?
Hmmm, i wonder if it's in valet mode.....
If no boost leak then it's looking like software..... What tool was the tuner using? Usually if the car has had revo etc alot of tools won't read them anyway so no real issue there. You need to take some vag logs and try see what is happening.
This is why a lot of tuners won't touch a car that has had "trial" software on it before such as revo. Although you are told the code is deleted it is impossible for a binary code to delete its self so it just reverts to their version of standard. A
Have you sorted this problem out yet? You would hope the experts would know what it was but it seems funny it lost the power when the stock map was downloaded off the car.
I do loads of these remaps with no problems, the other possible thing it could be is corrupt data in the ECU. Sometimes when a different tuning package is used to read the data the car can either lock up or have problems, REVO's system been an example of this.
Do you know if the car had been remapped prior to you owning it and been reset to stock code before you bought it. If it was the encryption on the stock code would be unreadable to the other tuners system especially if the file writer put a "NO READ" encryption on the file.
Some systems work like this, stock code is downloaded and encypted to their system on download. New tuned file is uploaded with same encryption this stops people copying other peoples work. Car is re-sold with stock file loaded back on, but this will still be encrpted to last persons code even though the car drives as standard.
New person comes along with different remapping software reads encrpted data, and file recognises someone is copying data. This is how the REVO system works, it can not be altered or changed with all other remapping programs.
Not saying this is 100% the problem but seems a bit too coincidental especially if the tuning company tried to load a tuned file over the top and it did nothing.
If you can find out what tuning system the garage used let me know as i may have some ideas.
id guess a previous remap has been upset or put in valet mode.
not lowered is it?
I've had the car since it was 18 months old and i bought it from a SEAT main dealer, as far as i know its never been remapped.
The place thats trying to fix it have found the problem is when the car is running, something is restricting the throttle and only allowing it to open less than 50%. The strange thing is the car is showing up no faults on VAG com.
They seem to be closing in on the problem at least and i'm hoping i might get it fixed this week.
