help sourcing clutch/flywheel for big bhp 4WD
4wdibiza
4wd all the way
Oct 20, 2011
305
cardiff
HI GUYS AS ABOVE REALLY. can anyone point me in the right direction in what cluch are good for road race drage race ect , oviously its not a standard fitment clutch as im running 02m box, can people show me what clutched there using , many thanks
Jan 13, 2010
440
UK
South Bend Clutch Kit
South Bend Single Mass Flywheel
JBS use this on they GT35 TT running 450+ bhp and 400ftlb
yellonvi-R
4,321
birmingham
I had an exedy stage 2 cluth in my old evo 4 and it was excellent the bite and grip it gave through gear changes was like backbraking ;)
Jul 4, 2007
1,674
bristol
and yet my stage 3+ have been fine.... all of them.
No issue with the clutch once it was fitted. installing it was the issue the clutch release arm hits on the pressure plate. And bolts scrape the housing.
This was off the shelf clutch from spec only I used g60 fly which Im guessing they designed their lightened flys to sit slightly different than the g60. But the said I should have no issue with running the g60 fly with their clutch so miss sold in my opinion.
Nov 2, 2004
9,334
South Wales
No issues for me on Spec stage 3. Used a lightened ABF flywheel on mine, just recently sold it and it looked mint when i took it off.
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
18
glos.uk
I run ABF/G60 fly also.. lightened, but thats off the back not the front.
maybe yours was a rogue one? I have fitted 3 of these ok to badgerwagen/lupo so far.
ibizacupra
Jul 25, 2001
31,333
18
glos.uk
any more veiws on this , what clutch kit to run wit o2m box
southbend would be one of my choices also for what its worth
on road cars, with BT I use dual mass luk flywheel, luk pressure plate mated to sachs paddle drive plate. works fine so far
4wdibiza
4wd all the way
Oct 20, 2011
305
cardiff
bill as you no im running 4wd in my ibiza , what clutch and fly would you recomend me for 02m box with ayp engine, turbo setup im running phillw's gt3071r
