right i have a boost problem
in the morning or the car is cold the sai pump runs then turns off which would normally give u boost after its done what its doing
but no i get no boost atall how ever long i drive it and the actuator is movable in and out with no resistance and can hear air moving somewhere (not a boost leak) all vac hoses are intact
then i pull the pipe of the n112 valve (tssssssss) then the acctuator goes stiff and start car up and i have boost
i have done the n249 bypass and its been done for months
any ideas people , can i bypass the n112 without removing the sai ?
