amd are doing the forge one 600 fitte djust had it done to mine
This is what it looked liked halfway through. The crash bar has to be cut around the cooler as its a lot wider than the forge one, and you need to grind some of the plastic from the inside of the bumper, none of which can be seen when its back on.
This is everthing i used.
3 of these
http://cgi.ebay.co.uk/63mm-2-1-2-ID...14&_trkparms=72:1683|66:2|65:12|39:1|240:1318
2 of these
1 of these
http://cgi.ebay.co.uk/Medium-TwinPa...72205QQcmdZViewItemQQ_trksidZp1742.m153.l1262
1 of these
http://cgi.ebay.co.uk/2-5-TURBO-INT...d=p3286.c0.m14&_trkparms=72:1689|66:2|65:12%7
2 of these
http://cgi.ebay.co.uk/BLACK-76mm-63...2:1683|66:2|65:12|39:1|240:1318C39:1|240:1318
Also some good jubilee clips to replace the crap ones that come with the pipe kit, all the other couplers are to replace the blue ones you can see in the picture in previous posts as they are rubber.
