cuprajkd
Hello all i am new to this forum and VAG 1.8T engines so a bit unsure even after reading up on the search option
If i was to get a diverter valve for the cupra r 225, theres a choice of forge 007, forge split-R and a Bailey DV26? Is that correct?
Do they all work ok? Are they all reliable? Do they all make a different noise?
Help much appreciated thanks everyone :)
iirc the Bailey DV26 is a BOV and if it is it will cause you problems.
Try searching for split r mate, all the info you will ever need.
I use a Forge 007p as it was recommended to me by JBS when I had my map installed and it's been great. The noise it made was'nt important to me but this is definately effected by your induction setup. If you're looking for the noise the Cosworths and the GT4's make you're going to struggle as these are atmospheric. LCRs hate atmospheric dump valves.
i have on mine forge split R and the engine is fine plus a little noise -i love it:):):)
thanks for the info guys i will check up on forge split r as i am after a little bit of noise but not after cosworth loud lol
thanks again
