Hi, can anyone shed any light on my VAG com results i got from tonights scan.
Sunday,29,November,2009,18:57:07:56783
VCDS Version: Release 908.1
Data version: 20091018
Chassis Type: 6K - Seat Ibiza/Cordoba
Scan: 01 02 03 08 15 17 25 45 56
Mileage: 122430km/76074miles
Address 01: Engine Labels: Redir Fail!
Part No: 6K0 906 032 AA
Component: 1.8L 20VT EU3 0002
Coding: 10500
Shop #: WSC 77880
5 Faults Found:
17695 - Boost Pressure Control Valve (N249): Open Circuit
P1287 - 35-00 - -
17832 - Secondary Air Injection System; Bank 1: Leak Detected
P1424 - 35-10 - - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16687 - Cylinder 3: Misfire Detected
P0303 - 35-10 - - - Intermittent
17769 - Cylinder 3 Ignition Circuit: Open Circuit
P1361 - 35-00 - -
Readiness: 0010 0000
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
Part No: 1J0 907 379 AF
Component: ASR 20 IE CAN 0001
Coding: 13404
Shop #: WSC 00000
3 Faults Found:
00283 - ABS Wheel Speed Sensor; Front Left (G47)
35-00 - -
16-10 - Signal Outside Specifications - Intermittent
04-10 - Mechanical Malfunction - Intermittent
Address 08: Auto HVAC Labels: 6K0-959-291.lbl
Part No: 6K0 959 291
Component: AUTOCLIMA-220 X06.00
1 Fault Found:
00792 - A/C Pressure Switch (F129)
03-10 - No Signal - Intermittent
Address 15: Airbags Labels: 1J0-909-60x-VW3.lbl
Part No: 1J0 909 609
Component: N AIRBAG VW3 SG 0002
Coding: 00078
Shop #: WSC 06402
No fault code found.
Address 17: Instruments Labels: 6K0-920-xxx-17.lbl
Part No: 6K0 920 901 D
Component: 6K-KOMBIINSTR. VDO V02
Coding: 00442
Shop #: WSC 00000
Part No: IMMO
Component: IDENTNR: SEZ7Z0A1189973
IMMO-IDENTNR: SEZ7Z0A1189973
Address 45: Inter. Monitor Labels: Redir Fail!
Part No: 6N0 951 171 C
Component: Innenraumueberw. 0003
1 Fault Found:
01463 - Alarm triggered by Sensor for anti-theft alarm System
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 6K0 035 186 C
Component: Radio GRO 1V32
Coding: 00401
Shop #: WSC 06402
End ---------------------------------------------------------------------
The AC fault i know if legit as the pipe is broken. The N249 has been bypassed, but im not sure about the rest.
Not sure about this cylinder misfire? Changed all 4 coilpacks this week.My ABS and TCS light are on, it was blowing fuse 8 a while ago and going into limp mode so i changed it for a stronger fuse and that worked for a short time. Then i could hear the abs kicking in and pumping at low speeds and now it just stays on.
Anyone have any ideas? MAF related?
Coding: 10500
Shop #: WSC 77880
5 Faults Found:
P1287 - 35-00 - -
P1361 - 35-00 - -
Coding: 13404
Shop #: WSC 00000
3 Faults Found:
35-00 - -
1 Fault Found:
Coding: 00078
Shop #: WSC 06402
Coding: 00442
Shop #: WSC 00000
Part No: IMMO
1 Fault Found:
Coding: 00401
Shop #: WSC 06402
