HID Problem
adp
55
Swansea
Hi guys,
Fitted my HID's from diane shop after christmas, and ever since they have been on when you turn them on passenger one ignites for about 5-10 secs then just goes off. But if you put them off and on again then it stays on fine, no problems! Its a bit less bright though than the other one.
Was wondering does anyone have any ideas of what it could be, i know i can return the ballasts etc to hong kong but thats major hassle and would prefer to sort it out myself if possible!
Cheers :)
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
Yeah mine has done this for the last 8 months
every time in hit a bump in the road my passenger side goes off (sometimes 10 times in the 20 minute drive to work). I have to turn off lights and turn them on again and it works fine...
I still need to send it back but haven't bothered yet
Davem
145
Birmingham
I know HID kits in general do this. Occasionally only one will be on. But if its happening that regular then i would say you do have a problem.
Regarding brightness, make sure they are both set at same height as can make one look alot brighter than the other etc if set incorrectly.
kyle'87
Modding Disease
Sep 15, 2008
868
Ruislip
I just got a set and the passenger side is flickering. I tested it all and its definatly the ballast so sending it back. Thats all I can recommend mate
If not look around ebay for a single ballast but then thats another cost
adp
55
Swansea
I knew i would probably have to send it back, just the hassle now of taking it all out again! Did you just email diane shop and ask for the exchange?
kyle'87
Modding Disease
Sep 15, 2008
868
Ruislip
I got mine from a different company but im sure its the same principles.
Email them > they tell you to swap them all about > you tell you done this > they tell you to send back the ballast > you send it back with a reference number > you get your new one sent out when they get the busted one > you spend another few hours fitting the new ballast hoping it works this time
F4
Hey guys looks like we all have similar issues, i had a problem wid my hid's aswell one went of approximately 10 sec after switchin' it on and if i switch it of and on again it would do the same.
So, here's what i did, swapped the bulbs over and it was still doin the same on the same bulb which meant the ballast was fine and i also realised that the bulb has changed its colour in the centre like a greyish sort of, anyways
Ordered new bulb got it fixed and its all good, hope that helps :)
