The beam pattern with the nightbreakers is already broken, so I reckon the antiglare will help ..
looked to see wehre i was gonna fit the ballasts and thought inside the wing ontop of the wheelarch with the sticky pads...
however seen this pic
lookslike hes stuck a screw into the headlight unit.. surely thats not too good as it effectively breaks the seal of the unit?
also noticed this guys kits a 55w... one i was sent is a 35w
I zip tied the N/S ballast up near the battery & he O/S one is wedged inbetween the washer bottle pipe & inner wing.
I think the above kit isn't the Ultimate kit so it won't have the "soft" start digital ballasts & uses 55W so the ECU doesn't throw up a bulb failure.
well they're in.......... stuck the ballasts on with the doublesided pads on the headlamp like the above pic. may wack a self tapper in it aswell just to make sure it doesnt fall off.
have to say i'm muchos impressed... the light is absolutely bright white. will get some pics tomorrow![]()
Sounds good, very interested to see what the anti-glare bulb looks like prior to me fitting mine
There you go Moley
i just fired them on with the doublesided pads which were supplied.... tempted to maybe stick a short self tapper in each ballast just to make sure they dont come off.
