All done now mate tbh, ordered and will see what they are like when delivered!
better be good!
You wont be disappointed...I've got 4300k on both dipped & main beam bulbs (H7 & H1).
The 4300k are a brilliant white, an with the H1's as well it's like driving in daylight on the back lanes in the dark.
A friend has 6000k on his MX-6 and they're a nice colour, slight blue tint, but nothing obvious!
Yup, but only if you want both dipped beam (normal driving) and high beam (flash / full beam)
There is a litle bit of modification required if you go for the H1's as well, but TBH the H7's are more than enough!!
I'm just a gadget / gizmo freak ;)
I'd strongly recommend just buying the H7's for the main driving beam to start with, as you may find you don't need or want the full beams as well, as the H7's are enough. Depends on your driving though :)
I've contemplated changing the location of the ballasts a number of times... so the one thing I'd say about the HID guide I made is use the locations as a guide and see if there is anywhere else you can find to put them. You may decide to use the same as mine... you may not. It's all good :)
ay i might take a poicture...
i used the same as ur drivers side...but it flaps about a bit as the metal bracket is quite flimsy....
the other one looks good bent under the wing between battery and wing! :D
damn you people i'd have money if it wasn't for you lot!!!! :D
just ordered myself some gone for the 6k one was tempted with the 5k as wanted a slight blue tinge but nothing more
It's the drivers side one that I'd change TBH, the passenger side is nice and secure against the wing, that's not going anywhere! Even with a larger diameter air intake beneath it, it's a great fit.
Excellent... you know it makes sense! The 6k is a really nice colour too, just about right IMO :D
so has teh 4k got any blue in it at all, is it just pure white??
Pretty much pure white.
There's a tiny hint of blue as they warm up after you switch them on, but then white white white.
It's really nice for the back lanes, but for visual appeal a touch of blue is good!
I'll be keeping the 4k bulbs for the main beam tho.
yeah would like the lower temp to give more visibilty but would like a nice tinge of blue for the look so hopefully 6k is spot on.............i know i will never say i wish i went higher.
