it will perform better in the colder temps, due to the air being denser.
Its MPG is always worse in the cold, but it does seem to perform at its best when cold, ive got to say though temp doesnt make much difference to its power, just MPG.
A couple of things to think about:
Does the poor MPG correlate with where you buy your diesel from? Unless you always buy from the same place, keep a log of where you buy your fuel and see if it matches up. Supermarket diesel in particular often gives less mpg.
Also, in colder months the fuel will be winterised, which means less energy content per gallon. This will vary from source to source, so again it's worth keeping a note of where you buy from.
Yeah thats something to bear in mind, thanks.
Although generally i always get my diesel from the same Shell garage. I try not to use supermarket fuel, ive used it once this year and the MPG was quite low.
Well ill see how i get on over the next week/tank full with the MAF cleaned and a fuel system cleaner in now.
Thanks.
