ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,330
19
glos.uk
Whats the highest k03s airflow anyone logged on their ibiza's
curious..
just made a badger5 induction kit on an ibiza with new k03s and its figures are... better than expected. logged from stock airbox to large green cone filter and significant increase is g/s logged.
thanks
Think mine was 193g/s.
I'll dig out the logs but it was deffo in the 190's which is when i worked out the 100%+ injector duty cycle.
The highest i've actually logged is 189 g/s. But i know Dave and Phil can beat that ;)
Code:
Group A:	'002
	RPM	Load	Inj. On Time	Mass Flow
TIME
STAMP	 /min	%	 ms	 g/s
0.57	1640	9.8	1.64	3.11
1.17	1720	85.7	10.25	30.83
1.77	1880	97.7	11.07	38.58
2.37	2080	120.3	13.12	53.39
2.97	2320	145.1	16.4	68.5
3.57	2600	167.7	19.27	88.94
4.17	2920	190.2	21.73	112.5
4.78	3280	191.7	23.37	127.42
5.37	3640	191.7	22.96	144.69
5.98	3960	191.7	23.37	153.61
6.57	4240	191.7	22.96	160.31
7.17	4560	191.7	22.14	166.86
7.78	4800	188.7	21.73	171.72
8.37	5040	184.2	21.32	180.39
8.97	5280	178.2	20.5	180.86
9.57	5480	171.4	20.09	181.19
10.17	5680	167.7	19.27	181.53
10.77	5880	164.7	18.86	181.33
11.37	6000	161.7	18.86	187.61
11.97	6200	157.9	18.04	187.94
12.57	6320	154.1	17.63	186.97
13.17	6440	152.6	17.22	186.92
13.77	6600	148.9	16.81	189.53
14.37	6680	147.4	16.81	188.5
14.97	6800	145.1	16.4	187.31
15.57	6920	142.1	15.99	187.61
16.17	7000	140.6	15.99	188.89
Does it go well bill? Because mine really shifts to be honest.
Whats the spec on it and whats your thoughts to running it on a 3" maf and 380's?
Its runs a brand new k03s (and I think still a little tight if thats possible), miltek dp/cat/system in 2.5", green open cone filter, and CC2 on it
Its goes 'ok' but not wow quick. Airflow almost flatters to deceive I think but it ran 168g/s on its stock airbox & paper filter and jumped to this 194g/s from fitting the green cone I made up for it.
boost 20-22psi peak and holds 15psi to 6k
dialed in an additional 4.5 degrees timing as it was'nt pulling any Cf's under boost.
It has an exchange maf on it, bosch and element number is correct as I was dubious.
heck of an airflow. might have to log mrsB lupo again since I changed its ramair out for an open cone green filter.
