hilla dont wanna hijack the thread mate but have you changed the follower yet? gonna give it a try today but looked at that guide and whats that tdc thing all about?
Are you fitting an uprated fuel pump? Heard somewhere that it was required.
Is this Stage 1 or 2?
HPFP isn't required for stage 2 mate, it's stage 2+. Stage 2 is 340-350bhp.
I'm going for just a stage 1 map until I get the exhaust next year, probably before the 'Ring.
Yeh, took the follower out yesterday, was really easy actually! Just followed the quide on the Golf forum, was piece of pie. Just drain the fuel out of the bleed nipple, unscrew the bottom hose (made of metal), take the 2 sensors out (one on top, one to the left hand side), and unscrew the 3 Torx bolts on the unit. The whole thing just slides out, and exposes the follower.
Mine will need replacing soon, so gonna order one this week and fit it.
I'll post another guide if you want pal?
iv just had a look at the golf one its says dummy proof ha did you put oil on the follower then when you put it back in? ive got a new follower now.
Na it was coated in oil, and I made sure it had plenty on when I put it back in. Just need to order mine now, then it'll be ready for the map.
To be fair though, the car feels great at the moment, doesn't need the map!
You been drinking:doh:..................... of course you need more POWER:D
fitted dv today mate easy as. Left the follower off for now its only done 20k i reckon itl be fine might swap it in 5k
Car looks great dude.
I have the exact same coil over set in the house and getting them fitted next Saturday. What front & rear height did you set them at ?
You will not be disappointed mate, they're top notch. Feel quite standard in a straight line, but soak up bumps much better. When you come to the bends, there's no body roll, and the nose just goes where you point it. They're awesome :D
As for height, we set them up at the height set in the manual that came with them, but I may lower the front a bit more. Can't remember the exact height, sorry pal.
Yeh probably be ok for another 5K, mine wasn't actually that worn - I would of taken a picture but no way was I getting my phone covered in oil! Told you the DV was easy, have you noticed any improvement?
dunno really mate it feels same i think haha but mine was ok wasnt it before hand not split. should it feel quicker more responsive?
FAO Kez:
And the original invoice dated 8/6/10
Cheers :D
