hot start problem ibiza ASZ pd130
digby130?
pocket rocket
Aug 10, 2008
305
exeter/london
hot start problem:
ive had a hot starting problem on my ibiza fr pd130 ASZ engine
so far replaced my temp sensor and had my injectors and cylinder head cleaned and seal replaced.
whilst getting a spare fuse from a friend we ran a volt meter across the battery to rule that out.
results were: 12v without key and with ignition on, then it dropped to 10v whilst it started and then back up to 14v whilst running! so probably not the battery....starter motor?
other things i think i need to check (after some research) are :
ignition coil
fuel pump
crank sensor
can anyone shed any light or suggest any more things to check please?
thanks in advance!
joop200789
330
Barnsly
been reading into this my self could be a faulty temp sender or other are saying the engine needs 250 rpm before the injectors will fire.
dues to the heat of the engine its slowing the cranking down.
when i can be bother am going to current drop test the battery check all wire to starter motor and earths clean them up
other then that is the stater motor not spinning fast enough
does you start fine when cold?
digby130?
pocket rocket
Aug 10, 2008
305
exeter/london
yeah when cold its fine :)
ive already replaced the temp sensor with no avail :(
going to take it to another garage/friend of a friend whose a vag mechanic (3 try now lol!) although just got my heating bill in since november so maybe not haha
mymorph
417
wolves
yep got my heating bill too for the 1/4. £450 near as. i thought it might be more with the cold snap we had.
got any mods on the car? and a vagcom visit required me thinks
you say pd130? and ignition coil???
digby130?
pocket rocket
Aug 10, 2008
305
exeter/london
I've got a hybrid garrett pd130 turbo, seat sport ic and custom remap to suit
I had a chat with the mechanic acquaintance yday and he reckons it could be the fuel pump!
The stuff i quoted I need to check was after mainly looking at mkiv forum and reading their problems with the pd130
I've had vag comm on it and the only thing we could find wrong (with the guy who tuned it) was that the actual fuel level was 20units under te requested.
The thing I don't understand is that if it was te fuel pump, surely there would be a problem on cold start ups as well?
Bondiblu
Enthusiast
Mar 18, 2007
1,648
Cheshire
It seems to be a fairly common issue on the TDI PD's, a lot of Cupra TDI's do the same. I think some VAG-COM logs need to be done, when cold, and repeated when hot and compare the 2, sounds like one of the sensors are playing up.
I have read that a faulty MAP sensor can have this effect as well as temp sensors.
joop200789
330
Barnsly
also on renaults when they get hot they struggle to start it turns out to be the crank shaft sensor
but deffinalty need to put it on vag com
digby130?
pocket rocket
Aug 10, 2008
305
exeter/london
i thought we only have MAF sensors? but im probably wrong lol! where abouts is the MAP sensor in the engine bay? is it something i can change myself? very low on funds until...ever lol so needs to be as cheap as possible in terms of fitting lol!
Bondiblu
Enthusiast
Mar 18, 2007
1,648
Cheshire
Yes there is a MAP or thrust, pressure sensor. Mounts near the top of the intercooler on the ASZ engine. Part No. 038 906 051 C
It monitors the boost pressure or Manifold Absolute Pressure
Bondiblu
Enthusiast
Mar 18, 2007
1,648
Cheshire
Possibly because when it's cold it feeds in more fuel like a choke on old cars and when it's hot the air is less dense??? Just something I came across, while reading an article. Mine tends to struggle to start when hot too.
digby130?
pocket rocket
Aug 10, 2008
305
exeter/london
cool..that sounds interesting lol! another thing to add to the list to check out haha!
tonight...drove to my gf's (about 5/6 mins), stopped for 10, started like normal.
then to my parents place from my gf's (about 25 mins drive) another 10 minute stop and the car wouldnt start...it cranked and started ticking over but then just gave up and died out. waited about 5 seconds and restarted how it is always doing on hot starts.
anyway, drove back to mine (about 15/20 mins) and stopped, started her up again and this is what happened:
http://www.youtube.com/watch?v=M_5CwRMRPMg
which is its normal behaviour on hot start ups
joop200789
330
Barnsly
when the engine cold its start fine in half a second just when the engine is hot and been left for 2 mines. struggle like hell sometimes
