damon6uk
1.2 nahh cupra
Oct 15, 2010
1,257
Kingston upon hull E.Yorkshire
If its the same material as a Leon.. heat it up and peel it off.. then get some tar remover on the gluey shite it leaves :)
its obvious when you look, there are 3 plastic rivets, you need to break them off then they just pull off dead easy. I ruined mine though when i took them off, loads of marks round where the rivets were. I just had a new pair sprayed up then swapped them over
I think it would look cool.
Skinning is way more expensive that wrapping though!
If I decide to go through with it (very unlikely as buying new wheels soon ha ha), i'll keep you posted :D
Sorry if this comes across as a dim question, but you literally heated them up and pulled them off? Nothing more? I just don't want to go doing something stupid because i misunderstood it!
No but I many could help once you take the clips out but I did this guide on another post
There is three of these circle things
Find a way to clip them off I have a bent flatblade screw driver so It was a little easy.
But unclip them I can guarantee to 1 of the 3 will break a little because mine did on both side.
Once unclipped pull from the back towards the front of your car, they are stuck on with double sided tape stuff, so give it a tug it won't break.
Any questions just ask I'll do a video if it becomes easier :)
