I need to check my actuator. I'm thinking of attempting this with it fitted.
Am I correct in thinking that if I connect the actuator directly to the inlet manifold then as boost builds it will hit a point overcoming the spring pressure and begin to open the wastegate. At this point I read of the value on my boost gauge and this would be it's pressure setting..........correct?
If boost continues to build up and up, then I can assume the actuator is faulty?
