Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
When I did my CTS, I topped up that day, checked later that afternoon and still fine having driven ~40 miles, then it was the following morning that it dropped.
sounds right.
4 litres is typical when doing a coolant change, i managed nearer 5 but i know i drained it 100%. heater matrix etc is an area not alwayas drained.
You dont say if you have let it run to operating termperature, as if you only ran it for a bit the coolant wont have been fully circulating due to the thermostat being closed.
Its lifetime coolant (G12) so i wouldnt worry about how much you changed, although i guess you have not measured how much you drained and compared to how much you have replaced?
Id leave some in the car somewhere as it might drop more when you are up to temperature.
(bearing in mind if it is fully filled when coolant gets hot it will expand and sit higher in the expansion tank)
andcupra is that right what iv done mate?![]()
