Mine is whining aswell toke it to the garage told I may need new gearbox soon but selects every gear smoothly just slight whining noise manly in first gear. Do you think this is worth a try literally just seen this threat
Worth a try. My whine began in 3rd and then crept into the others.
Yh Deffo going to try it worth a go need to replace wish bones as well so I'll do it the same time.
Did mine on saturday whilst doing the clutch. Was noisy in 5th on over run. Noise gone:D.
Thanks to the OP. Could have been paying out for a gearbox build.
Rich
Did mine earlier this year. Cured the whining in 1st gear, and it also tightened up the gear change throughout the box - well worth the £20 odd outlay (and an hour with the spanners)
What parts do I need to fix this problem, can someone give me the actual name of the parts and who to get them from as I'll get it orderd today, I've got a humming noise in 3rd gear starting to piss me of now, it's not loud but I can hear it.
Just quote them these part nos
Shim WHT-001-976
Cap 02M-301-211-B
Dealers or TPS
Just orderd them, shim £4 cap £4 pluss vat so £10 if TPS gonna go get them now, thanks guys I'll update you later when I've fitted them.
Yeh I'll do that just woried now that I may not have the correct gear box, Cupra 180 54plate gearbox MQ7C6M?
Hear a pic of my service book
Sent from my SM-G357FZ using Tapatalk
Have a look at the end of your gearbox (under the arch) you should see a large black plastic cap about 2 1/2 inches across. That be it.
Also the drain and re-fill plug takes a special splined socket on mine.
Worth a check before you shell out on oil you cant use.
Looks plastic lol off to collect the parts now
Got the parts now of to get the weeman from school then to head down and fit the part I'll update you once finished thanks guys
