AviTurbo
Beeza FR 2005
Apr 17, 2009
132
Israel
hi,
i tried to replace the gear gaitor but couldn't remove the knob because of this metal clip around it
someone have any clue how can i get rid of it??? and once i remove it , do i have to buy a new one from the dealer ?
thanks
job done!
thanks for all the replies.
here are some pictures , i've also played with the gear knob a little and painted the white stiches to red.
hope you like it.
the new gaitor
perfect fit!!
the metal ring is a bit loose though
That`s what I did when I changed mine, and used pliers to squeeze it back together... still going strong!
A bit late, but, I used two smallish screwdrivers and opened up the crimped ends slightly - then as above used a blunt pair of side cutters to close them up again. (I've forgotten if there is one or two ends crimped!)
