Thanks @grabania for the hint and for supporting me! I already checked some Youtube videos the last days and already realized that I need to unplug the purple lock first... Well, again something I learnd the hard way
I´m also now aware where BCM T73C is located. Seems to be even more complicated to work on that plug, as at least im my car there is almost no space for working in that area.
Regarding Module 16 - here is what my latest full scan provided:
So it seems to be present, but is has part nnumber 5Q0.
So as I´m not 100% sure if I understood your statement correctly, could you please confirm once again that wiring from BCM T73C is not necessary for me although I plan to upgrade to "Steering column switch: 5Q1 953 513 EA" / "Clock spring: 5Q1 953 549 F"?
Because this is what I basically would consider as upgrading from 5Q0 to 5Q1...
Would be jackpot if this step wouldn´t be necessary.
Fahrzeug-Ident.-Nr.: XXXXX Kilometerstand: 71460km
01-Motorelektronik -- Status: i.O. 0000
02-Getriebe -- Status: i.O. 0000
03-Bremsenelektronik -- Status: i.O. 0000
05-Zugangs-/Startber. -- Status: i.O. 0000
08-Klima-/Heizungsel. -- Status: i.O. 0000
09-Zentralelektrik -- Status: i.O. 0000
10-Einparkhilfe 2 -- Status: i.O. 0000
13-Distanzregelung -- Status: i.O. 0000
14-Raddämpfung -- Status: i.O. 0000
15-Airbag -- Status: i.O. 0000
16-Lenkradelektronik -- Status: i.O. 0000
17-Schalttafeleinsatz -- Status: i.O. 0000
19-Diagnoseinterface -- Status: i.O. 0000
2B-Lenksäulenverrieg. -- Status: i.O. 0000
42-Türelektr. Fahrer -- Status: i.O. 0000
44-Lenkhilfe -- Status: i.O. 0000
47-Soundsystem -- Status: i.O. 0000
4B-Multifunktionsstg. -- Status: i.O. 0000
52-Türelektr. Beifahr. -- Status: i.O. 0000
5F-Informationselek. I -- Status: i.O. 0000
69-Anhänger -- Status: i.O. 0000
A5-Front-/Vorfeldkamera -- Status: i.O. 0000
D6-Lichtsteuerung links 2 -- Status: i.O. 0000
D7-Lichtsteuerung rechts 2 -- Status: i.O. 0000
Adresse 16: Lenkradelektronik (J527) Labeldatei:| DRV\5Q0-953-549.clb
Teilenummer SW: 5Q0 953 507 JA HW: 5Q0 953 549 E
Bauteil: Lenks. Modul 003 0140
Revision: -------- Seriennummer: 01101804401424
Codierung: 6C10
Betriebsnr.: WSC 00049 770 00225
ASAM Datensatz: EV_SMLSKLOMQB 020002
ROD: EV_SMLSKLOMQB_020_VW37.rod
VCID: 7EA12866707C994ABDF-802A
Kein(e) Fehlercode(s) gefunden.
