Suddenly while I was driving the car had an unexpected behavior as I was releasing the gas pedal.
It made a "brake effect" As if I was going form 3rd to second gear, a cut/brake effect.
I noticed that while the car was not in motion but working my Rpm pointed @ 1000... ( instead of 800-830).
I assumed it was something that had to do with the intake...
So I replaced every pipe that lead to the intake ( see 1, 2, 3, 4), except the sensor see 5 No errors in VagCom).
I also cleansed my K&N filter and pipe with WURTH product and gasoline ( see 6).
My mechanic cleansed everything that had to do with the intake regulator ( see 7 ) and adjust it to basic function ( it needed a reset to get it's basic function cause it wasn't as it should ).
The abnormal effect stopped for 1-2 days.............
BUT ...
3 days ago it came back ( the vehicle worked fine for 2 days) I noticed that this was happening if I go above 4.300 RPM and I was wondering the only thing that stands now ( after the whole mechanical repair) is my tunned ECU / chip.
Do you think that something is wrong with the tunned programing of my ECU???
Any other suggestions, please advice ?
Best regards,
Dimitris
BUT ...
Best regards,
Dimitris
i was thinking the same as above! mine did the same and it was the crank sensor.
( plus mine as well )
