has exhaust come apart between center pipe and downpipe?
i always take the skirts off when working on stands or when car is jacked up. hopefully the rattle will just be the 2 pipes rubbing a little where the clamp is.
Bit of a problem, got my gear linkage sorted but when i go into first it feels like second gear when i pull away, same with the other gears, some are higher some are lower? Any ideas?
my gearbox felt different after swapping. has slower 1st gear, same 2nd but faster 3rd and 4th gear.
Different box code?
Go out & see what speed you're going at 2900rpm - it should be 59mph
The 1.4 8v rev limit is 5800rpm IIRC, which is 118mph - this test will confirm if you have a longer FD (from a diesel)
