crack5111
my car is running rich and im not sure where to start as there are no fault codes on the ecu and it could be the coolant temp sensor,air flow meter or lambda probe?the only other thing i could think of is ive made my own de-cat pipe and ive unplugged and removed the second sensor.i was just wondering if this could cause it even tho i did the de-cat quite a while ago and its only started running rich and using lots of fuel? cheers
ive recently put four new beru coil packs and a set on ngk iridium plugs and ive done oil and filter recently and i fitted a cold air induction kit a little while ago so i wouldnt of thought it would be anything to do with that
