Ibiza cupra tdi 56 plate DPF?
lcjay
433
London
Thinking of looking at a 56 plate ibiza cupra tdi just wondered if they had DPF filters and if the cause major headaches? or is it 2007 onwards?
I know you can have them removed/deleted but how much are we talking and will it cause problems come mot time or any other problems
lcjay
433
London
Really, whys that?
Are the cupra tdi 160 cams really as bad as people say and would i be better looking for a 130fr? will lumpy idle/smoke give the cam away?
What other things should i look out for on either the cupra or fr tdis? is it normal engine,turbo,clutch/dual mass flywheel as well as suspension bushes? Rusty front arches and hatch?
Apr 13, 2011
1,934
hull
The cams seem to be more of a problum on the older versions but still if serviced regular shouldn't be a problum. Rusty front arches are a problum due to the sound deadening in the side arch easyly removed.
The fr s are basicly the same engine so still do suffer with the cam faults.
Duel mass fly wheels can be a problum but on what car are they not the Cupra bushes are better than the fr a the Cupra is quite a good car tobehonest
AndrewJB
Aug 16, 2007
11,163
484
Maranello
The only engines fitted with DPF on the MK4 ibiza was the 1.4TDI and even then its the later ones.
The DPF was really first introduced on the Leon FR TDI PD170..
On diesel cars since about 2009 they all have them now
jimjam1973
if you are intrested, having to sell mine as I have a company car
06 plate Ibiza tdi fr in yellow, 76k fsh, mot, tax £3500
look on gumtree Essex its on there
