Ibiza fr, Lots of codes all at once, No response from ABS controller.
Sep 12, 2020
So two days ago i started my car to go to work and it lit up like a Christmas tree, power steering light, yellow abs light, TCS light, Red handbrake light, and EML. was too early tp start looking at it so i took the Passat instead. got round to having a look today, first checked the battery noticed it was not charging while the engine was running, log story short, load signal wire from alternator had snapped now fixed and charging fine.
TCS light stayed on for a while while i was scanning and tinkering, after a test drive to see how it runs it eventually went off (Car runs fine btw) i then scanned the car again results can be seen below, on scanning i noticed no communication with the ABS control module, tried to access this and no response, i have since checked all of the fuses on top of the battery box and did a continuity test on them to make sure they are working okay.
I also disconnected the battery and ECU to see if this would jump start anything (No Joy) however i only disconnected the battery for around 1 min so may need to extend this to get a proper reset.
anyone seen anything similar, seems very strange to get a whole host of codes all at once, I honestly thought repairing the load signal wire would solve the lot!
Scan results:
Address 01: Engine Labels: 038-906-019-ASZ.lbl
Part No: 038 906 019 NF
Component: 1,9l R4 EDC 0000SG 7000
Coding: 00102
Shop #: WSC 06402
VCID: 68DF815008EA110A7D-49D8
VSSZZZ6LZ5R089550 SEZ7Z0D2745447
3 Faults Found:
17911 - Load Signal from Alternator Term. DF
P1503 - 35-00 - Implausible Signal
18061 - Please check DTC Memory of ABS Controller
P1653 - 35-00 -
18057 - Powertrain Data Bus
P1649 - 35-00 - Missing Message from ABS Controller
Readiness: 1 1 0 0 0
Address 08: Auto HVAC Labels: None
Part No: 6L0 820 043 B
Component: CLIMAtronic PQ24 0301
Shop #: WSC 00000 000 00000
VCID: 2541C864EF78CC6286-50E6
2 Faults Found:
00792 - A/C Pressure Switch (F129)
000 - -
00457 - Control Module for Network (J519)
013 - Check DTC Memory
Address 09: Cent. Elect. Labels:. 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 D
Component: 0000 BN-SG. 1S34
Coding: 00012
Shop #: WSC 06402
VCID: 3C770D002CF26DAAC9-5072
2 Faults Found:
01316 - ABS Control Module
49-00 - No Communications
01598 - Drive Battery Voltage
07-00 - Signal too Low
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 AE
Component: 0E AIRBAG VW5 07 0010
Coding: 12357
Shop #: WSC 06401
VCID: 7AFBCB186646939A9B-5072
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 6L0-920-xx0-17.lbl
Part No: 6L0 920 920 P
Component: KOMBI+WEGFAHRSP VDO V13
Coding: 00445
Shop #: WSC 00000
VCID: 387F111018CA418A2D-5072
1 Fault Found:
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: 006A GATEWAY CAN 1S34
Coding: 00014
Shop #: WSC 06402
VCID: 70EFE930303AD9CA25-50E6
1 Fault Found:
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 10121
Shop #: WSC 06402
VCID: 6FEDEA4C2D04C6323C-5072
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
79-00 - Please Check Fault Codes
Address 46: Central Conv. Labels:. 6Q0-959-433.clb
Part No: 6Q0 959 433 E
Component: JS Komfortgerát 0002
Coding: 00064
Shop #: WSC 06402
VCID: 3D71000437E864A2FE-4A3A
Subsystem 1 - Part No: 6Q1959801A
Component: JS Tõrsteuer.FS KLO 0202
Subsystem 2 - Part No: 6Q1959802A
Component: JS Tõrsteuer.BF KLO 0202
3 Faults Found:
00928 - Locking Module for Central Locking; Front Driver Side (F220)
27-00 - Implausible Signal
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
01312 - Powertrain Data Bus
End-------------------------(Elapsed Time: 03:35)--------------------------
Sep 12, 2020
Sorted it all today turns out the small 10a fuse inside the car had been knocked loose some how ? not a total waste of time as the load signal wire which was broke
Sep 11, 2024
¿Recuerdas qué fusible era? Es decir, ¿qué controlaba? Tengo la misma avería, o al menos el mismo diagnóstico.
