mja8_uk
Hi
My X reg ibiza 1.4 is very poorly
please help.
I noticed a growing patch of oil outside my house. Popped my bonnet and discovered that the right side of the engine compartment is covered with oil and the oil level seriously low. The oil has leaked from the top of the engine beneath the plastic cover holding the air filters. The left side of engine near the alternator and air filter are clean.
I have got a pic of it but I couldnt work out how to insert it, insert image didnt seem to work.
The breather pipe from the engine entering the filter on the right had popped off and was covered in oil. I think that this pipe may be the source of the oil, when I took the filter cover apart the right hand filter was contaminated with oil. There was a load of yellow mustard residue in the pipe that enters the filter on the left which I cleaned out.
Not sure if it is of any relevance or not, but the pipe in the centre was split but I have replaced this now. The split pipe came out of a sensor or something located in front of air intake after the filter.
I’ve topped up my oil and cleaned as much of the spilt oil off the engine. For the time being I’m just going to keep an eye on it.
Can anyone comment on whether the oil is likely to have come out of the suspect pipe? Should there even be oil this pipe?
Any other ideas what I can do to fix it? Are there any other likely places where the oil could have leaked from?
Does anyone know what the item where split pipe is/does?
Thanks in advance.
Martin.
Thanks in advance.
Martin.
