ibiza rear brakes
killer205
206
i just fitted my new brake pads calipars and disks but the wheels seems very hard to move round have i done something wrong or will it correct its self when i put brake fluid in and start the engine
andyj
There's no F in Quality..
you may have overtightened the rear wheel bearing... or the pads might just be 'tight' against the disc.
Try starting the engine etc and pressing the brake pedal a few times, if this doesn't cure it, then it's probably an over tight wheel bearing.
cupraspark
51
Huntingdon
brakes
If i was you i would check the calipar piston is screwed back far enough use a pair of circlip pliers turn clockwize, also make sure that your sliders are not seized:)
sickpupppy
lmao@ my typo'd user name
Jul 8, 2009
82
carlisle, the frozen north
if you don't have any circlip pliers to hand, i found that long nose pliers also work with a little care (my old audi 80, R.I.P)
oh (and my old Laguna, now R.I.P also :(, but its french so no great loss)
however yes long nose pliers can work too, saves expensive tool purchases
