GEnDisorda
Hi all,
I'm sure this is a pretty common issue that many will have come across before. Its not actually my car , the Mrs is on holiday and comes back in two days.
Someone has taken her driver side mirror clean off and I would Ideally like to be able to say A will cost ,X B will cost Y as soon as she gets in the door.
I've got some quotes on the way , But
Has anyone replaced one them selves ?
How easy are they to pick up 2nd hand ?
How easy are they to fit ?
Is there a difference between the SE and other models ?
Is there a difference between 3 and 5 door ?
Any help would be greatly appreciated
I cant upload the photos as I don't have posts, but the outer painted case is fine. The rest of it is smashed.
That link did not get me directly to your picture(s) !
Edit:- also, is it electric folding version or manual folding version?
Thanks for the reply.
Sorry I cant post links, you have to remove the spaces.
They are Manual folding.
https:// (delete) postimg. (delete) org (delete)/image/ (delete)bifuudmf7/
Ouch, I am a fool!
Right, I think that you need to look at the main assembly and you should find a VAG part number moulded into the plastic, use that when looking for a new mirror, and check here to see if that number has been superceded now:- http://etka.cc/
