<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>
Originally posted by BenS1:
Flapper has informed me that Seat do a suspension upgrade for the
Ibiza...
<Quote>
SPORTS SUSPENSION KIT
Ibiza ONLY ,4 Bilstein dampers + Eibach (20mm) Lowered springs (4hrs fitting)
6K1 071 600 Sports suspension kit
Ibiza £499.99
bit dear huh ?
sorry SEAT set the price for this stuff , if it helps i think RSD are doing a few similar kits PS9 i think theyre called
</Quote>
Has anyone tried this upgrade?
Is it any good?
Is it really worth £500????
This isn't the kit thats on the Cupra R is it coz that only lowers by 7mm.
Has anyone tried the PS9 kit?
Any other kits?
Cheers,
Ben
<HR></BLOCKQUOTE>
If Seat Sport have done anything to the spec of their sports dampers I'll be very surprised. Off the shelf Bilstein dampers and Eibach springs and they want to charge £500 !! I seriously doubt they are any different or better than the regular Sprintkit Bilsteins you can but for £330.
Are they worth it performance wise? Absolutely, if they're anywhere near the same spec as my Jettas Bilsteins.
Having driven my Beezer on track, back to back with my Jetta, I have to "sadly say" that the Beezer SUCKS in the handling dept. I hate to say it, especially as I just spent many 1000's of pounds buying it. It is absolutely awefull with stock suspension when pushing on. 210 kit in a straight line is great, but give it some braking and cornering and its rubbish and bordering on dangerous! ABS should pull you up in a straight line, and yet is wants to swap ends on an undulating track, usch is the suspension bounce and wallow.
I say this as a warning to anyone rushing out onto a track with their new pride and joy. Be careful and get used to it, build the speed slowly. The limit of braking and adhesion on cornering are much lower than you would think.
I am getting a PSS9 kit (damping and ride height adjustable as opposed PSS, non damping adjustable only ride height) and hope this will sort out the serious handling problems this car has on the limit.
TCS on/off does'nt actually turn it off either! Why fit a switch to turn it off if it does'nt 100% turn off??? Stupid. It still cuts boost back to 5psi mid corner, whilst rolling around the corners on stock suspension. Nasty habbit that.
Having had the opportunity to learn about the beezer in a safe environment on track, I was glad I had restrained from playing on the road, as I am sure there would be an accident at some point. Point and squirt - fine. Driving spritedly around corners, no chance. Back to back with my Jetta (200bhp also) was a revelation. 9 seconds a lap at Combe slower, the Beezer was, and it had many vices to worry you. The beezer was faster to accelerate out of corners, and faster in a straight line, yet lost 9 seconds per lap as it could not slow down in a straight line or carry and speed through a corner. Very dissapointing. Very sad.
the good news is I think a decent suspension package could fix many if not all of these vices, and make one hell of a car, on road and track. Nothing about my Jetta's setup could not be done to the
Ibiza.
eg. Eibach front and rear anti rollbars, Bilstein Sprintkit suspension, front upper strut brace, polurethane suspension bushes, and 7.5x16 wheels with 205-45-16 tyres. Lowered approx 40-50mm. 1m24s laps at Combe.
Just be careful.
Bill
http://www.badger5.co.uk
[Message edited by ibizacupra on 24 September 2001.]
