ESCY
I am working on this 02 reg Ibiza TDi 6 speed which has the following symptom. During hard acceleration after a few seconds the engine loses power & goes into a limp mode,& remains with lack of power until stopped & restarted.It then has full power until driven hard again.Fault 17965 Charge pressure control positive deviation is recorded each time.It thus appears that there is overboost.
1/The MAF has been renewed.
2/During actuator test the vacuum control unit pulses at the appropriate times.
3/Acctuator test lists a boost pressure solenoid test-could this be the culprit?
3/I understand egr faults can give this symptom?
4/Has it a variable vane turbo & could this be at fault?
Any hints gratefully received!
PS/ I also have an identical scenario on my Sk@!a Octavia TDi-which I have been too busy to investigate!
Regards Andrew Newman.
