The springs can be fitted to all caliper setup's i think!
Have a look and see if your setup can accomodate a spring
Heres the springs fitted
N/s part no 1K0615295
O/s part no 1K0615296
I think they were fitted the wrong way (i.e. on wrong side, the spiral should be near the handbrake pivot).
http://www.seatcupra.net/forums/showpost.php?p=4098714&postcount=1
also shown on refurbed calipers
With pliers or can even use hands as the springs are not heavily tensioned.
This is a great little mod, for peanuts! Just did this on mine, hoping to get rid of a light constant breaking noise that I can hear from the passanger side all the time above 20mph. I cleaned up the rear breaks and wound the pistons back in and added copper grease and moxy to try and prevent any siezing calipers (no issues with movement on the slider pins).
The mechanisim the handbrake cable attaches to, it seems to be movable (not too easily), but what is the default position meant to be when the handbrake is off or on? I only ask cos it seems that the arm in mine does not move whether it is on or off????? (its the part that the top arm of the spring attaches too). Is this meant to move when the handbrake is under tension...or does it just stay the same all the time???
Do you mean the crank arm that the handbrake cable attaches to at the caliper? It should move when the handbrake is applied, as it is applying mechanical pressure to the piston so as to apply the handbrake. It sounds as though you have a seized handbrake mechanism on that side.
Jack up that side, apply the handbrake and see if the wheel can be rotated. Now release it, and see if there's any difference.
The rest position should be 1mm off the end stop when the handbrake lever is fully released i.e. down as far as it will go.
