You ight want to sticky this as a guide for anyone thinkin of buying a forge FMIC.
Anyways the kit consists of two 300mm straight pieces which go across the front crash bumper,
to fit the bottom one you have to hack the crash bar to pieces and also cut away most of the mounting bracket, very poor design tbh!
Anyways my fix uses the pipework but in a differeant way BUT you need to purchase one new pipe.
The following pic, for the bottom pipe on the intercooler (1) to run like it does they have had to hack away all the mounting bracket!!
I know the new kit consists of a modified crash bar but if you don't get one then your stuck lol.
This shows what I mean, pic from forge.
Anyway here's my modified way, best thing is you can still fit the fog lamp and the fog lamp cover
You can see the new pipe (3) below, it's just a simple 51mm ID silicone hose, 90 degree bend and 120mm from the center of the bend to either end or 6" lol
Anyway the modified system, take the 300mm straight off the bottom intercooler joint (1) picture 1,
remove the forge 45 degree bend from the bottom hose going to the turbo (2) picture 1.
Slip this onto the intercooler bottom connector where (1) was, now (2), picture 3.
Use the long metal straight connector and join the 45 and 90 degree pipes together, picture 3.
Slip the small straight connector onto the open end of the 90 degree bend (3), cut down the straight (1) so that it pulls the 90 (3) as tight as possible to the radiator ect, picture 4.
I'll modify this tomorrow with pictures of the fitted bumper ect!!
Hope this helps you guys.
