milli
114
west midlands
Right lately when i indicate left its flashing quicker then normal which means a buld has gone, but then after a bit it will be fine. But today it started to flash quick and now its staying like it, had a quick look at the buld as it the front one and the fillament seems ok, but how on earth do you get to the back of the lights???
put yours indicators on and see which one isn't flashing. If it is the front you need to look at the back of the light and you will see a white bulb holder for the indicator bulb. Turn this 90degrees and it should pull straight out, you may want to unplug the electrical connection to this bulb holder to allow you to remove it from the car to change the bulb. hope that helps :)
edit: just a thought, my bro's cupra used to do this too; it was just a dodgey connection in the bulb holder. clean the connections and bend them slightly more towards the bulb to insure good contact
only had a quick look as it was pretty dark, but seems do be a lot of plastic behind the light, do i have to take any of this off?? will have another look tomorrow though
if it is the drivers side you should be ok, if it is the passenger side there are a few bits of plastic that need removing, 4 screws only from memory though - but even then it is tight!
yes it is the passenger side, i thought it may of been the for screws that are on the top to take it off, any pics??
yep, those 4 screws and then the plastic slides upwards:
(the plastic covers were not on mine when i took this photo)
i have quickly took the plastic parts off, but i dont find any way of getting my hand in there to change the buld, will try and take some pics in a bit as its freezing out there
