Yes the Australia one is on that link I gave you
They are the Skoda ones. Same file interchangeable across the brand. Its how they do the map files. So for maps if its a mib3 we pick the latest on offer. Currently shown in the link.
They are 2025.05 / 2025.06
A group of people that sniff out the latest map files of the Vag servers then get passed between the Vag forums. Seat / Cupra at the minute drag their feet and VW. Skoda at the minute have the latest and are best organised. Probably as connect services took off they lost interest in putting out timely maps. The window for updates was traditionally June and November. But with streamlining they do get the maps out earlier.
In the top post of the thread I placed all of the pdfs of how to do it for each brand for mib3 for good measure. All the same instructions. See attachments.
Usb C drive can be used or USB A with a USB A to C adaptor as long as it is wired for data. Some cheap ones arent. On the adaptor front that is. The car has USB C. 64gb is recommended for Europe but given you are in Australia with that 1gb upload you can get away with a smaller drive. Ext3 is the recommended format. Anything above 32gb is sold in Ext3.
You don't present to the car anything other than the maps to it on that drive. Nothing else, else it can get confused. Pull out any other USB Cs just to make sure.
The pdfs will talk about the format of the drive. Then the director position in the root is important as per the pdfs. The unit itself isnt a PC so doesn't take kindly to people trying to do it with an SSD drive. Thats happened. Then you press ignition or what have you. Take a picture before and after the map update. The YYYY.MM will change once completed. About 40 minutes for the European files. Should be much shorter for the 1 gb Australian file. Possibly a one or two minutes I guess.
This is where people like usbs with flashing LEDs to gauge the level of activity. For the European maps it is a mute point of when it finishes since the maps are designed for connect services as you drive across the continent it will download the next segment. For Europe its thought leaving it in a bit longer from when the YYYY.MM changes is a good idea but the LED activity tells you. People have seen the LED madly flashing after the update seems to be completed. You'd need no more than 40 minutes with it in. Europe more but as said nobody really knows.
The files are signature protected so you can't edit anything in them so if you open up the meta files you have to be very careful you dont save them. Just quit. You dont need to poke about inside them just unzip them and drop onto the USB.
I have a mib2 high unit, not mib3 but the process is similar in that the maps are written away to an internal SSD in the unit but on Seat / Cupra we are governed by "mapcare" but on mib3 they took off map update restrictions. It's like a VW, Skoda etc. Maps for life till they stop updating them.
All clear as muck. Just some rigour in file handling.
Wow... what an amazing response. I will take a good look when I get on my PC next.
Do you have any idea what Mib system I have ? How do I figure that out ?
Thank you again Tell.
Hello Tell and everyone else....
Sorry to revise a July 2023 Thread, however I was just wondering if anyone can tell me, if this is the latest software ?
Might be prudent to add that we are in Australia and we are always a few years behind.
Not sure what this system is... M3 or 2 or something else... it has all confused me a little but I will learn.
Is a Cupra Ateca VZx Build 2024 (sorry can't remember month right now) and it has several annoying issues with shutting down after turning off car... and not remember what media source or file is being played.
Details below.
Device Part Number 575035876G
Hardware H31
Software 0442
Navigation Database 22.12
Media Codec 2516a208c7c3d54ed8991b820f4671119a5ad1ce
It's a mib3. Telltale was the 22.12 date the others dont have that. Build 2024... a lot of clues. Mib3 was fitted to the 2020 and beyond models. Why I answered as mib3.
Reactions: steveyoshi
Sorry Tell, I didn't see that, I will have good read when I get near my PC. Anyway thanks for everything. Outatanding
Reactions: Tell
