injector cleaner worth it ?
snaps
Just got myself a red 54 plate altea 2.0tdi sport with only 49k , 1 owner fsh . Now as it was used not much by a women it didnt really get abused and i reckon power is down a bit . Ive scanned using a modis and no fault codes . No smoke rattles or faults . Just wondered about sticking some decent injector cleaner through it ? Imalso gonna check front drivers side lower boost ppipe as it looks a bit oily .
zx6rninja_rider
I use miller oils diesel ecomax and found it made a hell of a difference when I first put it in (tip double dose the first treatment) I use it on every tank
jamborino
85
I use Millers when filling up with regular diesel. It's good stuff. It makes the engine quieter and smoother and it certainly seems more responsive. Trouble is it stinks a fair bit!
I also find that Shell's V-Power diesel achieves the same benefits without having to add Millers, although it's pricey.
snaps
Been reading up about the millers and seems good results . Seems to be more of a booster then a cleaner ? Are the bkd engines ok to use cleaners/boosters ie damaging the injector tips etc ?
