I never said I knew everything there is to know about the
Ibiza. I just know if you change for bigger injectors with the standard turbo it will over fuel and risk blowing the turbo
If you are looking to find bigger injectors from another car then surely good advice on changing the turbo first is more relevant compared to knowing if the injectors are actually different?
Ballenapene there are ways of says things and all you needed to really say was the injectors are the same.
