Sold now, or did you buy it? Can't see why it couldn't be made to fit the LC, just depends if you have the effort and determination to get all the pipework fitted really
How are you going to mount it? Its quite thick to at 3.5" although if your lucky it might fit under the crash bar instead of having to cut it.
I think it could work using the basis of the standard pipework with a few tweeks. :)
Thats pretty wide to fit behind a crash bar because you want a gap between the cooler and air con rad so it operates efficiently.
I think you'll be able to sort it without to may problems.
