Intercooler location? Do I Definatly have one?
m0rk
sarcasm comes free
27,785
33
Clanfield, UK
when you put the front end back on, put the car on the ground - otherwise the chassis will change shape when the wheels are on the ground
Nov 2, 2006
1,241
Annaghmore
bebo.com
Didnt do this for the inner frame! Have had my head in there and tightened the bumber on when on the ground, just attached, everything behind was tight though. Had a check all seems ok, nothing moved, broken, twisted or otherwise. I had to put it up to tighten bottom screws on bumber and sump cover.
All is back on and working! There was a lot of sludge in the bottom pipework, took all off except the TIP which was ok when stuck a rag into it. Rest had a thinck coating and so had the intercooler. Hot water, fairy liquid and it cleared it out a treat. Some crappy routing and restrictions in there, Will post a pic later on one pipe in particular, EGR to intercooler oulet.
1,241
Annaghmore
bebo.com
I did dry it well. Let it drain, then used a garden blower that fits nicelt into the inlet holes to blow it through, got rid of all the water from it. Had a drive there in it and seems quieter and bit smoother on power. Next is EGR cleaning, goign to plug it tomorrow, vac hose that is. Info please: does the EGR flap stay open or closed when idling? Just so I know that im not pluging it in the open position allowing free flow of EGR gas.
Nov 2, 2006
1,241
Annaghmore
bebo.com
I fitted the catch can to the the rocker cover outlet through to can, then back into the t.i.p. Located can below airbox, not paid much time to better location yet. Is replaces that 5inch 90deg elbow on the rocker cover. I made the can myself from 3inch exhaust and made two cover plates, added a baffle inside to prevent blowback, a drain and a level guage. After 4k miles, approx, i caught about 150ml of oil residue.
*EDIT*
Picture of the can....
Intercooler before cleaning....
:banned:
Oil from the can after approx 4k miles....
No pictures of the install just yet, but it was tucked in under airbox, used battery clamp as fixing point. Hope this helps a bit.
pdh 14a
Mr Fussy
Jan 21, 2008
834
Swansea
Sounds a good idea! any pics? :)
Nov 2, 2006
1,241
Annaghmore
bebo.com
I used 1" piping to fit my adaptors, this also fits the T.I.P but is slightly big on the rocker cover point, jubilee clip is sufficient though. Get proper black hose or reinforced clear tubing from B&Q or that, can buy by the metre in there. Need to find the drain hole cap now to get it back on!
think you'll find there is more loss of oil with remapped Alteas. turbo/boost kicks in at lower revs and thus sucks more crap out of the breather pipe. gonna get one fitted to mine soon.
