That is VERY easy to fit,
The Toyo coolers used 225mm high cores and they worked, so one at 180mm would be a doddle.. And it has the 2.5" outlets to match the LCR 2.5" pipework,
You just need -
8x 68-73mm T Clamps
2x 63mm 45degree Silicone hoses
2x 63mm 45degree alloy pipes
2x 63mm 90degree silicone hoses
1x 63mm alloy joiner
The whole lots on ebay and INCLUDING the cooler core will come in @ under £200. Go buy,
Thanks for the info mate would it be ok that intercooler as its small and I have a stage 1 remap would I benefit anythink over the smic and would the intercooler be ok for a stage 2 remap or would the Toyo cooler be better cheers
Does anybody know which cooler would be better the one in the link or a Toyo intercooler also which would be better if I wanted to have a stage 2 cheers
