Is 20mm Spacers on the rear tooooo wide?
Nef
Looking Rather Dappa
Mar 30, 2009
626
Cambridge
thinking about either 15mm or 20mm spacers on the rear but is 20mm too wide, my card already lowered a fair amount of standard alloys. so is it too wide i ask :D?
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
how much room you got left horizontally when measured ?
or better still stick a 20mm baton of wood flush against the rim/tyre and rotate round to see what clearance is left ?
check vertically as well mind ;)
LeeC
I have 20mm on my rear alloys they are 7j alloy and still could squeeze a few more mm in. Wound down on coilovers but still have the adjuster in. Would still clear without it though.
AdamRoutley
Use The Force!!
Feb 22, 2007
1,827
Walsall
www.myspace.com
what a coinkidink jimski!
DannyC87
Rubbing is Racing :-)
Mar 4, 2008
3,459
with 15mm on the LCR I scrape the inside of the arches when laidened up on coilies..not much scrape tho; only over bumps!
