Havok316
Boost Junky
Jun 6, 2006
1,220
Weston-super-Mare
Hi all is this the oil blanking plug for the oil temp sender?
have u removed the black mount that holds the three connectors mate.Below that is where the blank plug is on top of the housing that u have pointed out.
All i have removed is the engine bay cover. Slightly above that is a plastic square thing which is holding 2/3 electric pipe things. Is that right?
remove that plate that holds the three plugs in place then you will see an allen key plug on the top of the filter housing mate.
