auq
Avoiding Potholes!
Feb 11, 2010
643
Leicestershire
Hi im a newbie to the forums!, i own a 2001 LC with AUQ engine fitted, i belive the engine has the K03s turbo fitted too, ive added a samco TIP, Forge Type R DV, N249 bypass, Cold air feed pipe, ive aquired a ECU from another car with the AUQ engine, it has the Jabba stage 2 remap software on it, will this cause more problems than good or am i safe to plug and play!
im also considering Miltek cat back system and front intercooler at a later date.
Any help or advice would be superb on this!!!!!
Thanx for the reply, im looking at a FMIC and a Milltek cat back system at some piont, so you wouldnt recomend trying this ecu? also if i plug this in what should i need to do regarding immob. i have VAG COM and also have the revo mapping software but not sure how th map!!!
PS. Adam mines the same blue as yours, nice colour
thankyou!
spose youd have to mimic / mirror the mods to what the other car had done to it - to even get close to what its set up for
, id imagine it would also have been set upon what fuel the previous owner chose to run 95 ron / 99ron etc
have you tried contacting jabba to see if they would adapt the map to suit you slightly
