am running a bsm carbon dynamics airbox it sounds da nuts![]()
well done
Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
What cai are people using for this? Ive got silver flexi hose but im pretty sure its attached to my airbox so wondering how it will attach with a cone there instead
mines now fitted and the dv sounds much nicer, although sat at 70ish though i can hear it hissing almost which i guess it should do as the boost isnt building its constantly releasing??
Anyway heres a pic of it fitted now
You going to have a proper bracket made to hold the filter? Yes we can all see the temporary cable tie
The hissing will be the air being drawn through the filter.
Couldn't you put your MAF in the middle of the two silicon tubes? It might give it a bit more cushioning?
oh right ok, should there be a cable tie around the pipe that comes off the top of the dv?
No problems here either, been on for about 1K now.
Maf readings are better than ever.
