BTW - The joiner elbows are 135 degrees , and not 45 .
45 creates a tight V shape - a U-turn in fact .
135 degrees is the geometric equivilant of what's in all your photos . from TIP to MAF that is .
Check out this shop for the right elbows .
http://stores.ebay.co.uk/REGALS-Motorsport_W0QQ_trksidZp1638Q2em118Q2el1247
notice furthr into each degree section, the angles drawn , and picture your engine bay area from TIP to MAF .
This looks perfrct and long - 2 x 152 mm.
http://cgi.ebay.co.uk/70mm-OD-135-T...photoQQcmdZViewItemQQ_trksidZp1742.m153.l1262
So is a straight piece of silicon hose called a 180 degree elbow? lol
Most companies (like forge and samco) label the elbows by the amount of degrees "off straight" the elbow is.
Different companies give them different angles .
I'm just saying geometricly the joiner we need isn't 45 but 135 .
old thread bump, just to make clear as im ordering the jetex setup with the forge silicon tubing, what size does the bend have to be? Some say 45degree some say 135degree? Can anyone clarify?
FMA45-70_Black-[New Code] - 70mm 45° Elbow Silicone Hose
That's what I ordered from Forge and it was the right one :)
Not going to buy mine from forge as they only do blue! Going to get the elbow from SFS performance as they can do red pipes:) In keeping with my colour scheme!
:sorry for the dumb question but will this defo fit mine ?
160mm
140mm
150mm
CENTER
320
CHROME
FC-07003
with a 70mm neck size as it was the neck size i not 100% on :p thanks
what shape would you say is best for fitment ? Cylindrical Filters or Conical Filters as in one you cant get a chrome top only rubber but seems like most ppl went for Cylindrical Filters ?
Mine arrived Friday, got the filter from Jetex, and the Samco hosing, hose joiner and clips from MerlinMotorsport.
At the moment just fitted the filter on the end of the MAF, as the samco hose elbow looks like its gonna need a fair bit cut off it as it's a very tight fit in that engine bay!
