Mine does this too but only when I accelerate and decelerate in the wet. I thought it was top mounts?
Mine used to do that, it was the wishbone bushes. Replaced with Cupra ones and it was okay (also needed a new ARB and bushes, but you have 06 onwards models which shouldn't have the ARB issue). Have you guys had yours changed yet?That was me driving down my street I'm not moving in the car at all, I'm braking then rolling then braking making it make the noise. At the end I'm drive down a bump where it goes from bricks to tarmac
Just been out and made myself a bodge winter grille!
Hopefully my car will warm up in less than 4 miles now it has less airflow.
Here's the sound of mine, wait till about 10-15 secs as it doesn't kick in till then.![]()
I saw this on at the Yorkshire meet, is it working did not get a chance to ask you.
I travel about 16 miles to work, the petrol Cupra used to heat up in about 4-5 miles and was OK, but the diesel takes longer and is bordering on 10 miles, looking for a similar tweak myself!!
Go out and grab each front wheel and try to rock it (you'll need to get both arms under the arch and use a bit of strength!). If you've a lot of movement within the arch then your bushes are knackered.
Also just to let you know Jordan that with the passenger seat out it defiantly sounds like a wishbone bush. The noise comes right from where the wish one is.
