Just fitted my SplitR DV. Few questions
Is it setup right? Discharge on the bottom, pressure in from the right? It dumps so guess it is.
Just I got a little confused as mine wasn't the standard Bosch valve, it was some kind of Forge one, al get pics up of that soon
Also, how do you no when you have the right settings on it by turning the top. Basically should be dump on red line when you rev it? Because right now it's dumping well before that. But haven't drove it out yet.
M87NER
MATNER
Mar 11, 2007
1,338
Stoke-on-Trent
Yeah thats the correct setup, basically its up to you how to set it up how you like-if you want the dump sound i've read somewhere that you turn it all the way anti-clockwise and the turn it about 7/8 time back clockwise that works well,
Rick1.8t
150
Dont set the Dv so it only opens at redline, thats not its purpose.
It should (and will if set correctly) 'dump' whenever boost pressure is there to vent, when you let off the throttle or change gear the dv will respond to being 'on vaccum' rather than postive or neutral pressure - so it should and will dump well before 7.5k if you let off the throttle or change gear
It will be feint at low rpm as the amount of boost generated at that point is lower than further up the rev-range.
Rick
Dan Cupra R
The Yellow Sub
May 2, 2006
1,514
Reading
You want it so the piston opens. Get a mate to check for you that the dv opens when you rev it.
On mine everytime I let off the throttle I get the 'whoosh'. More boost = louder whoosh.
Apr 24, 2007
985
W. yorkshire
put it this way on my LCR with 265bhp i only have mine turned approx 20 clicks and that holds boost levels well any firmer and it will not release boost properly and cause your turbo to stall
