thanks phil you make me want to proceed now :p
any idea why he said dont go over 3k? it will be ran for a month until i can afford to stage 2 it with a sports cat
i know a lad who ran a ko3s on standard map for month wilth no problems,so it will be fine to put them on. stage 2 is to get the best out of the turbo
you're a top man phil, he said it could cause running probs after 3k so it worried me a tad
On a standard map i went waaay past 3k without problems, some say its about 5k ish where the ko3 runs out of puff that with a ko3s on a standard map could run lean, so just don't push it to hard i'd say.
With stage 1, i would have thought it would be abit better.
from searching around, technically it will run fine on a stg1, but to get the most from it, a stg2 setup would be better, taking into account the mods you have
as most of the mods you have already point to a stg2 setup...as in a way its a bit pointless sticking with a stg1 map with all the mods you have as it is not bringing out their full potential and in essense the potential of the car and power as a whole
to be honest i just drove home from Birmingham tam worth and I didn't take it much over 4k so if thats the case I should be fine..
well there's only one way to find out if it will work...
the worst that happens is it goes into limp mode and i have a useless car :(
Mine was much better on stage 1 revo. No limp mode etc at all. stage 2 was a major dissapointment and a waste of the £ 50 upgrade price.
lol its being done tomorrow at 10am phil..
im not sure if amd is a custom map or a flash map like revo, if its like revo then il have no problems
the original map was done before i bought it
