just mixed oil viscocities - help!!!!!!
markster
My 1.4 8V Ibiza ran on 10W-30 Castrol Magnatec for the last 2 years.
I just changed the oil yesterday afternoon and had about half a bottle of 5W-30 Castrol Magnatec and half a bottle of 15W-40 Castrol Magnatec so I mixed them.
I came to start it this (cold) morning and it struggled a little, although was fine once warmed up.
Could it be a problem with mixing the oil viscosities (even though I used same brand) or is it likely that it's because it was cold this morning and I didn't turn over the engine much after replacing the oil and filters since yesterday so it just took time to get into the engine parts?
Just a little concerned
Jun 26, 2008
849
Sunderland
You should probably be ok mate, if there both synthetic (which they are). They will both dissolve in each other i would imagine giving you an oil with intermediate properties of both.
As for mixing Synthetic with Mineral i wouldn't recomend it, but if worst came to worst you should be ok in a reasonably modern car with good seals.
Keep an eye on it and if in anything else develops, post up.
jordyboy004
Leon Cupra 1.8t 20v
Apr 4, 2008
239
Isle Of Wight
ok so reading this i think ill be ok but just to maked sure....... i was usuin 5w30 part synthetic on my leon cupra 180. did an oil change yesterday and decided to start using 5w40 fully synthetic as i was told its better. but i still have 2l of the 5w30 part synthetic left. will this still be ok to mix in?
